CHPSC
Clwb Hwylio Pwllheli Sailing Club
The Heart of Welsh Sailing
Description of the image
IClogoInternational Canoe Class National Championships 1 - 4 September 2016
The roots of the class go back to the mid 1800's where paddling canoes where fitted with sails and raced, particularly in Britain, USA and Sweden. These boats have changed quite a bit since then but the main characteristics of the boat is a long narrow hull form with rounded transom and the famous sliding seat.
After many decades of development around the world including some famous designs from Uffa Fox, the hull shape had evolved into an optimal design based on the rules at that time. In the 1970's the class agreed to create an International one design hull shape based on lines drawn up by a Mr Peter Nethercot. The development of deck layout, fittings, rig and seat were still able to be developed within some broad rule definitions. The IC then became a stable platform and enjoyed worldwide status at the fastest single handed monohull in the world.
internationalcanoe.wales  - event websaite
International Canoe Class Website
CalonHwylioCymru
12.363MBMemory Usage436msRequest Duration
Joomla! Version4.4.13
PHP Version8.3.6
Identityguest
Response200
Templateg5_vermilion
Database
Server
mysql
Version
5.7.23-23
Collation
utf8_unicode_ci
Conn Collation
utf8mb4_general_ci
$_GET
array:3 [ "catid" => "159" "id" => "1376:intl-canoe-class-national-championships" "view" => "a...
$_POST
$_SESSION
array:1 [ "joomla" => "***redacted***" ]
$_COOKIE
array:1 [ "4cf75f85894b300e2c205a8e5d616277" => "0641aac9037aa5987a0ad3d84470f426" ]
$_SERVER
array:63 [ "LSPHP_ENABLE_USER_INI" => "on" "PATH" => "/usr/local/bin:/usr/bin:/bin" "TEMP" => ...
session
array:3 [ "counter" => 3 "timer" => array:3 [ "start" => 1747544269 "last" => 1747544270...
registry
array:3 [ "data" => [] "initialized" => false "separator" => "." ]
user
array:18 [ "id" => 0 "name" => null "username" => null "email" => null "password" => "***r...
plg_system_languagefilter
array:1 [ "language" => "en-GB" ]
  • afterLoad (458.86KB) (1.44ms)
  • afterInitialise (3.32MB) (133ms)
  • afterRoute (2.42MB) (75.83ms)
  • beforeRenderComponent com_content (27.49KB) (262μs)
  • Before Access::preloadComponents (all components) (70.75KB) (1.84ms)
  • After Access::preloadComponents (all components) (143.69KB) (1.88ms)
  • Before Access::preloadPermissions (com_content) (2.1KB) (27μs)
  • After Access::preloadPermissions (com_content) (1.46MB) (5.13ms)
  • Before Access::getAssetRules (id:1398 name:com_content.article.1376) (66.65KB) (117μs)
  • After Access::getAssetRules (id:1398 name:com_content.article.1376) (7.47KB) (166μs)
  • Before Access::getAssetRules (id:1 name:root.1) (751.18KB) (45.76ms)
  • After Access::getAssetRules (id:1 name:root.1) (6.02KB) (44μs)
  • afterRenderComponent com_content (430.52KB) (34.1ms)
  • Before Access::getAssetRules (id:8 name:com_content) (375.68KB) (29.69ms)
  • After Access::getAssetRules (id:8 name:com_content) (6.27KB) (57μs)
  • afterDispatch (2.23KB) (1.51ms)
  • afterRender (2.15MB) (104ms)
  • 1 x afterInitialise (3.32MB) (30.54%)
    133.24ms
    1 x afterRender (2.15MB) (23.91%)
    104.30ms
    1 x afterRoute (2.42MB) (17.38%)
    75.83ms
    1 x Before Access::getAssetRules (id:1 name:root.1) (751.18KB) (10.49%)
    45.76ms
    1 x afterRenderComponent com_content (430.52KB) (7.82%)
    34.10ms
    1 x Before Access::getAssetRules (id:8 name:com_content) (375.68KB) (6.81%)
    29.69ms
    1 x After Access::preloadPermissions (com_content) (1.46MB) (1.18%)
    5.13ms
    1 x After Access::preloadComponents (all components) (143.69KB) (0.43%)
    1.88ms
    1 x Before Access::preloadComponents (all components) (70.75KB) (0.42%)
    1.84ms
    1 x afterDispatch (2.23KB) (0.35%)
    1.51ms
    1 x afterLoad (458.86KB) (0.33%)
    1.44ms
    1 x beforeRenderComponent com_content (27.49KB) (0.06%)
    262μs
    1 x After Access::getAssetRules (id:1398 name:com_content.article.1376) (7.47KB) (0.04%)
    166μs
    1 x Before Access::getAssetRules (id:1398 name:com_content.article.1376) (66.65KB) (0.03%)
    117μs
    1 x After Access::getAssetRules (id:8 name:com_content) (6.27KB) (0.01%)
    57μs
    1 x After Access::getAssetRules (id:1 name:root.1) (6.02KB) (0.01%)
    44μs
    1 x Before Access::preloadPermissions (com_content) (2.1KB) (0.01%)
    27μs
152 statements were executed, 50 of which were duplicates, 102 unique82.02ms564.73KB
  • select distinct reference_table from jos_falang_content2.89ms1.01KB/plugins/system/falangdriver/falang_database.php:224Copy
  • SELECT `value` FROM jos_acyc_configuration WHERE `name` = "license_key"2.07ms536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acyc_configuration WHERE `name` = "last_cron_trigger"185μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acyc_configuration255μs896B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acyc_configuration327μs1.19KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_rsform_config169μs1.81KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_rsmembership_configuration516μs1.56KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'level'243μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'active_cron'169μs1.15KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'cron_next'124μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'queue_type'90μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'cron_frequency'85μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'queue_batch_auto'84μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM `jos_rsmembership_payments` WHERE `published` = '1' ORDER BY `ordering` ASC188μs880B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`membership_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_membership_shared` AS `s` LEFT JOIN `jos_rsmembership_memberships` AS `m` ON `s`.`membership_id` = `m`.`id` WHERE `s`.`published` = '1' AND `m`.`published` = '1' AND `s`.`type` IN ('article','category')145μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`extra_value_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_extra_value_shared` AS `s` LEFT JOIN `jos_rsmembership_extra_values` AS `v` ON `s`.`extra_value_id` = `v`.`id` WHERE `s`.`published` = '1' AND `v`.`published` = '1' AND `s`.`type` IN ('article','category')100μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `catid` FROM jos_content WHERE `id`='1376'130μs1.77KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT joomlatablename,tablepkID FROM `jos_falang_tableinfo`132μs800B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_languages ORDER BY ordering1.61ms1.61KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW FULL COLUMNS FROM `jos_languages`3.42ms1.52KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `parent_id` FROM jos_categories WHERE `extension`='com_content' AND `id`='159'164μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `parent_id` FROM jos_categories WHERE `extension`='com_content' AND `id`='83'115μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`membership_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_membership_shared` AS `s` LEFT JOIN `jos_rsmembership_memberships` AS `m` ON `s`.`membership_id` = `m`.`id` WHERE `s`.`published` = '1' AND `m`.`published` = '1' AND `s`.`type` = 'menu' AND `s`.`params` LIKE '2047'121μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`extra_value_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_extra_value_shared` AS `s` LEFT JOIN `jos_rsmembership_extra_values` AS `v` ON `s`.`extra_value_id` = `v`.`id` WHERE `s`.`published` = '1' AND `v`.`published` = '1' AND `s`.`type` = 'menu' AND `s`.`params` LIKE '2047'152μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`membership_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_membership_shared` AS `s` LEFT JOIN `jos_rsmembership_memberships` AS `m` ON `s`.`membership_id` = `m`.`id` WHERE `s`.`published` = '1' AND `m`.`published` = '1' AND `s`.`type` = 'frontendurl' AND `s`.`params` LIKE 'com_content%'120μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`extra_value_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_extra_value_shared` AS `s` LEFT JOIN `jos_rsmembership_extra_values` AS `v` ON `s`.`extra_value_id` = `v`.`id` WHERE `s`.`published` = '1' AND `v`.`published` = '1' AND `s`.`type` = 'frontendurl' AND `s`.`params` LIKE 'com_content%'94μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `membership_id`,`params` FROM `jos_rsmembership_membership_shared` WHERE `type` = 'menu' AND `published` = '1'96μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `extra_value_id`,`params` FROM `jos_rsmembership_extra_value_shared` WHERE `type` = 'menu' AND `published` = '1'517μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW TABLES5.8ms24.51KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_configuration1.76ms24.56KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin3.25ms1.53KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'acychecker' LIMIT 11.07ms1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'acymailer' LIMIT 1887μs3.95KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'amazon' LIMIT 1657μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'article' LIMIT 1189μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'birthday' LIMIT 1232μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'brevo' LIMIT 1181μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'createuser' LIMIT 1451μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `groups`.*, `groups`.title AS text, `groups`.id AS `value` FROM jos_usergroups AS `groups`241μs1.08KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'elasticemail' LIMIT 1202μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'forward' LIMIT 1152μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'mailgun' LIMIT 1185μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'module' LIMIT 1170μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'online' LIMIT 1445μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'override' LIMIT 1178μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'phpmail' LIMIT 1164μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'postmark' LIMIT 1188μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'qmail' LIMIT 1322μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'rseventspro' LIMIT 1181μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'segment' LIMIT 1190μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'sendgrid' LIMIT 1218μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'sendinblue' LIMIT 1172μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luecredentials' LIMIT 1185μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'lueintegration' LIMIT 1187μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luetransactional' LIMIT 1210μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luelist' LIMIT 1164μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'lueusers' LIMIT 1181μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luesender' LIMIT 1148μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luecampaign' LIMIT 1147μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luewebhooks' LIMIT 1154μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'sendmail' LIMIT 1153μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'smtp' LIMIT 1183μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'statistics' LIMIT 1136μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'subscriber' LIMIT 1180μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'subscription' LIMIT 1136μs12.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'surveys' LIMIT 1140μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'time' LIMIT 1185μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'user' LIMIT 1136μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'virtuemart' LIMIT 1210μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'managetext' LIMIT 1228μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT s.id, s.template, s.home, s.title AS long_title, s.params FROM jos_template_styles AS s WHERE s.client_id = 0 AND s.template = 'g5_vermilion' ORDER BY s.id360μs912B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `id`,`name`,`rules`,`parent_id` FROM `jos_assets` WHERE `name` IN (:preparedArray1,:preparedArray2,:preparedArray3,:preparedArray4,:preparedArray5,:preparedArray6,:preparedArray7,:preparedArray8,:preparedArray9,:preparedArray10,:preparedArray11,:preparedArray12,:preparedArray13,:preparedArray14,:preparedArray15,:preparedArray16,:preparedArray17,:preparedArray18,:preparedArray19,:preparedArray20,:preparedArray21,:preparedArray22,:preparedArray23,:preparedArray24,:preparedArray25,:preparedArray26,:preparedArray27,:preparedArray28,:preparedArray29,:preparedArray30,:preparedArray31,:preparedArray32,:preparedArray33,:preparedArray34,:preparedArray35,:preparedArray36,:preparedArray37,:preparedArray38,:preparedArray39,:preparedArray40,:preparedArray41,:preparedArray42,:preparedArray43,:preparedArray44,:preparedArray45,:preparedArray46,:preparedArray47,:preparedArray48,:preparedArray49,:preparedArray50,:preparedArray51,:preparedArray52,:preparedArray53,:preparedArray54,:preparedArray55,:preparedArray56)1.15ms8.19KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `id`,`name`,`rules`,`parent_id` FROM `jos_assets` WHERE `name` LIKE :asset OR `name` = :extension OR `parent_id` = 02.56ms213.48KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW FULL COLUMNS FROM `jos_content`576μs1.77KB/plugins/system/falangdriver/falang_database.php:330Copy
  • UPDATE `jos_content` SET `hits` = (`hits` + 1) WHERE `id` = '1376'338μs48B/plugins/system/falangdriver/falang_database.php:133Copy
  • SELECT `a`.`id`,`a`.`asset_id`,`a`.`title`,`a`.`alias`,`a`.`introtext`,`a`.`fulltext`,`a`.`state`,`a`.`catid`,`a`.`created`,`a`.`created_by`,`a`.`created_by_alias`,`a`.`modified`,`a`.`modified_by`,`a`.`checked_out`,`a`.`checked_out_time`,`a`.`publish_up`,`a`.`publish_down`,`a`.`images`,`a`.`urls`,`a`.`attribs`,`a`.`version`,`a`.`ordering`,`a`.`metakey`,`a`.`metadesc`,`a`.`access`,`a`.`hits`,`a`.`metadata`,`a`.`featured`,`a`.`language`,`fp`.`featured_up`,`fp`.`featured_down`,`c`.`title` AS `category_title`,`c`.`alias` AS `category_alias`,`c`.`access` AS `category_access`,`c`.`language` AS `category_language`,`fp`.`ordering`,`u`.`name` AS `author`,`parent`.`title` AS `parent_title`,`parent`.`id` AS `parent_id`,`parent`.`path` AS `parent_route`,`parent`.`alias` AS `parent_alias`,`parent`.`language` AS `parent_language`,ROUND(`v`.`rating_sum` / `v`.`rating_count`, 1) AS `rating`,`v`.`rating_count` AS `rating_count` FROM `jos_content` AS `a` INNER JOIN `jos_categories` AS `c` ON `c`.`id` = `a`.`catid` LEFT JOIN `jos_content_frontpage` AS `fp` ON `fp`.`content_id` = `a`.`id` LEFT JOIN `jos_users` AS `u` ON `u`.`id` = `a`.`created_by` LEFT JOIN `jos_categories` AS `parent` ON `parent`.`id` = `c`.`parent_id` LEFT JOIN `jos_content_rating` AS `v` ON `a`.`id` = `v`.`content_id` WHERE ( (`a`.`id` = :pk AND `c`.`published` > 0 AND `a`.`language` IN (:preparedArray1,:preparedArray2)) AND (`a`.`publish_up` IS NULL OR `a`.`publish_up` <= :publishUp)) AND (`a`.`publish_down` IS NULL OR `a`.`publish_down` >= :publishDown) AND `a`.`state` IN (:preparedArray3,:preparedArray4)765μs6.19KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1376) AND `reference_table`= 'content'321μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (159) AND `reference_table`= 'categories'250μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (159) AND `reference_table`= 'categories'261μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`911μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'616μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`661μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'382μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`811μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'379μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`652μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'322μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `m`.`tag_id`,`t`.* FROM `jos_contentitem_tag_map` AS `m` INNER JOIN `jos_tags` AS `t` ON `m`.`tag_id` = `t`.`id` WHERE `m`.`type_alias` = :contentType AND `m`.`content_item_id` = :id AND `t`.`published` = 1 AND `t`.`access` IN (:preparedArray1,:preparedArray2)320μs3.97KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `membership_id`,`params` FROM `jos_rsmembership_membership_shared` WHERE `type` = 'module' AND `published` = '1'180μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `extra_value_id`,`params` FROM `jos_rsmembership_extra_value_shared` WHERE `type` = 'module' AND `published` = '1'82μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'articles') ORDER BY r.ordering, r.id180μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`627μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'357μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT DISTINCT a.id, a.title, a.name, a.checked_out, a.checked_out_time, a.note, a.state, a.access, a.created_time, a.created_user_id, a.ordering, a.language, a.fieldparams, a.params, a.type, a.default_value, a.context, a.group_id, a.label, a.description, a.required, a.only_use_in_subform,l.title AS language_title, l.image AS language_image,uc.name AS editor,ag.title AS access_level,ua.name AS author_name,g.title AS group_title, g.access as group_access, g.state AS group_state, g.note as group_note FROM jos_fields AS a LEFT JOIN `jos_languages` AS l ON l.lang_code = a.language LEFT JOIN jos_users AS uc ON uc.id=a.checked_out LEFT JOIN jos_viewlevels AS ag ON ag.id = a.access LEFT JOIN jos_users AS ua ON ua.id = a.created_user_id LEFT JOIN jos_fields_groups AS g ON g.id = a.group_id LEFT JOIN `jos_fields_categories` AS fc ON fc.field_id = a.id WHERE ( (`a`.`context` = :context AND (`fc`.`category_id` IS NULL OR `fc`.`category_id` IN (:preparedArray1,:preparedArray2,:preparedArray3)) AND `a`.`access` IN (:preparedArray4,:preparedArray5)) AND (`a`.`group_id` = 0 OR `g`.`access` IN (:preparedArray6,:preparedArray7)) AND `a`.`state` = :state) AND (`a`.`group_id` = 0 OR `g`.`state` = :gstate) AND `a`.`only_use_in_subform` = :only_use_in_subform ORDER BY a.ordering ASC1.04ms4.81KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT LOWER(REPLACE(a.title, " ", "")) FROM jos_viewlevels as a WHERE a.id IN ('1','7')223μs552B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT LOWER(REPLACE(u.title, " ", "")) FROM jos_usergroups as u WHERE u.id IN ('1')126μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `a`.`id`,`a`.`title`,`a`.`catid`,`a`.`language`, CASE WHEN CHAR_LENGTH(`a`.`alias`) != 0 THEN CONCAT_WS(':', `a`.`id`, `a`.`alias`) ELSE a.id END AS `slug`, CASE WHEN CHAR_LENGTH(`cc`.`alias`) != 0 THEN CONCAT_WS(':', `cc`.`id`, `cc`.`alias`) ELSE cc.id END AS `catslug` FROM `jos_content` AS `a` LEFT JOIN `jos_categories` AS `cc` ON `cc`.`id` = `a`.`catid` WHERE `a`.`catid` = :catid AND `a`.`state` = :state AND `a`.`access` IN (:preparedArray1,:preparedArray2) AND (`publish_up` IS NULL OR `publish_up` <= :nowDate1) AND (`publish_down` IS NULL OR `publish_down` >= :nowDate2) AND `a`.`language` IN (:preparedArray3,:preparedArray4) ORDER BY CASE WHEN `a`.`publish_up` IS NULL THEN `a`.`created` ELSE `a`.`publish_up` END DESC915μs2KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1461,1367,1368,1369,1370,1371,1372,1373,1374,1375,1376,1378,1469,1366,1426) AND `reference_table`= 'content'521μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`649μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'440μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`620μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'326μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`605μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'315μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'352μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`975μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'350μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`598μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'335μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`578μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'343μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`773μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`1.04ms3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'617μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'component') ORDER BY r.ordering, r.id961μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `language`,`id` FROM `jos_menu` WHERE `home` = '1' AND `published` = 1 AND `client_id` = 01.4ms592B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (3350) AND `reference_table`= 'menu'392μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`1.11ms3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'483μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`815μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'435μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`719μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'368μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`604μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,83,159) AND `reference_table`= 'categories'386μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c2`.`language`,CONCAT_WS(':', `c2`.`id`, `c2`.`alias`) AS `id`,CONCAT_WS(':', `ca`.`id`, `ca`.`alias`) AS `catid` FROM `jos_content` AS `c` INNER JOIN `jos_associations` AS `a` ON `a`.`id` = `c`.`id` AND `a`.`context` = :context INNER JOIN `jos_associations` AS `a2` ON `a`.`key` = `a2`.`key` INNER JOIN `jos_content` AS `c2` ON `a2`.`id` = `c2`.`id` INNER JOIN `jos_categories` AS `ca` ON `c2`.`catid` = `ca`.`id` AND `ca`.`extension` = :extension2 WHERE `c`.`id` = :id AND c2.access IN (1,7) AND c2.language != 'en-GB' AND (c2.publish_up IS NULL OR c2.publish_up <= '2025-05-18 04:57:50') AND (c2.publish_down IS NULL OR c2.publish_down >= '2025-05-18 04:57:50') AND c2.state = 1408μs1.47KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `a`.`menutype`,`a`.`title` FROM `jos_menu_types` AS `a` WHERE `a`.`client_id` = 0171μs8.64KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT m.id, m.alias, m.path AS route, m.level, m.parent_id FROM jos_menu AS m WHERE m.menutype = 'members' AND m.parent_id > 0 AND m.client_id = 0 AND m.published >= 0 ORDER BY m.lft701μs1.98KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (6530,6531,2830,2835,2883,2887,3060,2884,2885,6814,2886,2888,2889,2905,2494,3024,3272,3787,6551,1971,2528,2907,792,793,2906,1173,695,2463,2005,1965,585,4335,3096,2908,2022,2047,2600,2601,2602,7756,487,3025,7755,7428,6644,6642,4642,4645,4577,4644,4643,3026,1972,5585,3800,2084,2096,2087,2088,2089,2090,4444,2093,2094,2092,2091,2095,2097,4607,6411,6552) AND `reference_table`= 'menu'1.63ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT m.id, m.alias, m.path AS route, m.level, m.parent_id FROM jos_menu AS m WHERE m.menutype = 'sub-menu' AND m.parent_id > 0 AND m.client_id = 0 AND m.published >= 0 ORDER BY m.lft324μs784B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (7754,7757) AND `reference_table`= 'menu'263μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT SUM(CASE WHEN `a`.`next_execution` <= :now THEN 1 ELSE 0 END) AS due_count,SUM(CASE WHEN `a`.`locked` IS NULL THEN 0 ELSE 1 END) AS locked_count FROM `jos_scheduler_tasks` AS `a` WHERE `a`.`state` = 1367μs1.37KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_list WHERE type = 'standard'462μs2.08KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_field453μs18.39KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_form WHERE active = 1 AND type != 'shortcode'289μs912B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'head') ORDER BY r.ordering, r.id303μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'body') ORDER BY r.ordering, r.id372μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'everywhere') ORDER BY r.ordering, r.id356μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` LIKE "%regacy" OR `name` LIKE "%\_sub"817μs552B/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW TABLES2.76ms24.51KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `alias`,`id` FROM `jos_content` WHERE id = '463'167μs592B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (463) AND `reference_table`= 'content'269μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`544μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108) AND `reference_table`= 'categories'540μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`501μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108) AND `reference_table`= 'categories'322μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`431μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108) AND `reference_table`= 'categories'385μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`583μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
