CHPSC
Clwb Hwylio Pwllheli Sailing Club
The Heart of Welsh Sailing
Description of the image
CalonHwylioCymru
12.526MBMemory Usage492msRequest Duration
Joomla! Version4.4.13
PHP Version8.3.6
Identityguest
Response200
Templateg5_vermilion
Database
Server
mysql
Version
5.7.23-23
Collation
utf8_unicode_ci
Conn Collation
utf8mb4_general_ci
$_GET
array:3 [ "catid" => "201" "id" => "1689:psc-spring-series-5" "view" => "article" ]
$_POST
$_SESSION
array:1 [ "joomla" => "***redacted***" ]
$_COOKIE
$_SERVER
array:62 [ "LSPHP_ENABLE_USER_INI" => "on" "PATH" => "/usr/local/bin:/usr/bin:/bin" "TEMP" => ...
session
array:3 [ "counter" => 1 "timer" => array:3 [ "start" => 1748969798 "last" => 1748969798...
registry
array:3 [ "data" => [] "initialized" => false "separator" => "." ]
user
array:18 [ "id" => 0 "name" => null "username" => null "email" => null "password" => "***r...
plg_system_languagefilter
array:1 [ "language" => "en-GB" ]
  • afterLoad (458.53KB) (2.23ms)
  • afterInitialise (3.31MB) (74.05ms)
  • afterRoute (2.43MB) (159ms)
  • beforeRenderComponent com_content (27.49KB) (277μs)
  • Before Access::preloadComponents (all components) (70.75KB) (4.83ms)
  • After Access::preloadComponents (all components) (143.69KB) (6.24ms)
  • Before Access::preloadPermissions (com_content) (2.1KB) (33μs)
  • After Access::preloadPermissions (com_content) (1.46MB) (11.21ms)
  • Before Access::getAssetRules (id:1851 name:com_content.article.1689) (66.65KB) (146μs)
  • After Access::getAssetRules (id:1851 name:com_content.article.1689) (7.47KB) (152μs)
  • Before Access::getAssetRules (id:1 name:root.1) (931.97KB) (84.16ms)
  • After Access::getAssetRules (id:1 name:root.1) (6.02KB) (47μs)
  • afterRenderComponent com_content (439.2KB) (35.18ms)
  • Before Access::getAssetRules (id:8 name:com_content) (395.91KB) (17.48ms)
  • After Access::getAssetRules (id:8 name:com_content) (6.27KB) (70μs)
  • afterDispatch (1.14KB) (1.29ms)
  • afterRender (2.11MB) (94.51ms)
  • 1 x afterRoute (2.43MB) (32.26%)
    158.63ms
    1 x afterRender (2.11MB) (19.22%)
    94.51ms
    1 x Before Access::getAssetRules (id:1 name:root.1) (931.97KB) (17.12%)
    84.16ms
    1 x afterInitialise (3.31MB) (15.06%)
    74.05ms
    1 x afterRenderComponent com_content (439.2KB) (7.16%)
    35.18ms
    1 x Before Access::getAssetRules (id:8 name:com_content) (395.91KB) (3.56%)
    17.48ms
    1 x After Access::preloadPermissions (com_content) (1.46MB) (2.28%)
    11.21ms
    1 x After Access::preloadComponents (all components) (143.69KB) (1.27%)
    6.24ms
    1 x Before Access::preloadComponents (all components) (70.75KB) (0.98%)
    4.83ms
    1 x afterLoad (458.53KB) (0.45%)
    2.23ms
    1 x afterDispatch (1.14KB) (0.26%)
    1.29ms
    1 x beforeRenderComponent com_content (27.49KB) (0.06%)
    277μs
    1 x After Access::getAssetRules (id:1851 name:com_content.article.1689) (7.47KB) (0.03%)
    152μs
    1 x Before Access::getAssetRules (id:1851 name:com_content.article.1689) (66.65KB) (0.03%)
    146μs
    1 x After Access::getAssetRules (id:8 name:com_content) (6.27KB) (0.01%)
    70μs
    1 x After Access::getAssetRules (id:1 name:root.1) (6.02KB) (0.01%)
    47μs
    1 x Before Access::preloadPermissions (com_content) (2.1KB) (0.01%)
    33μs
154 statements were executed, 50 of which were duplicates, 104 unique118ms567.29KB
  • select distinct reference_table from jos_falang_content2.36ms1.01KB/plugins/system/falangdriver/falang_database.php:224Copy
  • SELECT `value` FROM jos_acyc_configuration WHERE `name` = "license_key"170μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acyc_configuration WHERE `name` = "last_cron_trigger"137μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acyc_configuration243μs896B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acyc_configuration258μs1.19KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_rsform_config233μs1.81KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_rsmembership_configuration461μs1.56KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'level'537μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'active_cron'537μs1.15KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'cron_next'615μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'queue_type'417μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'cron_frequency'289μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'queue_batch_auto'426μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM `jos_rsmembership_payments` WHERE `published` = '1' ORDER BY `ordering` ASC552μs880B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`membership_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_membership_shared` AS `s` LEFT JOIN `jos_rsmembership_memberships` AS `m` ON `s`.`membership_id` = `m`.`id` WHERE `s`.`published` = '1' AND `m`.`published` = '1' AND `s`.`type` IN ('article','category')401μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`extra_value_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_extra_value_shared` AS `s` LEFT JOIN `jos_rsmembership_extra_values` AS `v` ON `s`.`extra_value_id` = `v`.`id` WHERE `s`.`published` = '1' AND `v`.`published` = '1' AND `s`.`type` IN ('article','category')331μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `catid` FROM jos_content WHERE `id`='1689'580μs1.77KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT joomlatablename,tablepkID FROM `jos_falang_tableinfo`662μs800B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_languages ORDER BY ordering833μs1.61KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW FULL COLUMNS FROM `jos_languages`563μs1.52KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `parent_id` FROM jos_categories WHERE `extension`='com_content' AND `id`='201'334μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `parent_id` FROM jos_categories WHERE `extension`='com_content' AND `id`='90'433μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `parent_id` FROM jos_categories WHERE `extension`='com_content' AND `id`='88'389μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`membership_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_membership_shared` AS `s` LEFT JOIN `jos_rsmembership_memberships` AS `m` ON `s`.`membership_id` = `m`.`id` WHERE `s`.`published` = '1' AND `m`.`published` = '1' AND `s`.`type` = 'menu' AND `s`.`params` LIKE '2047'1.38ms640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`extra_value_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_extra_value_shared` AS `s` LEFT JOIN `jos_rsmembership_extra_values` AS `v` ON `s`.`extra_value_id` = `v`.`id` WHERE `s`.`published` = '1' AND `v`.`published` = '1' AND `s`.`type` = 'menu' AND `s`.`params` LIKE '2047'2.8ms640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`membership_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_membership_shared` AS `s` LEFT JOIN `jos_rsmembership_memberships` AS `m` ON `s`.`membership_id` = `m`.`id` WHERE `s`.`published` = '1' AND `m`.`published` = '1' AND `s`.`type` = 'frontendurl' AND `s`.`params` LIKE 'com_content%'946μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`extra_value_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_extra_value_shared` AS `s` LEFT JOIN `jos_rsmembership_extra_values` AS `v` ON `s`.`extra_value_id` = `v`.`id` WHERE `s`.`published` = '1' AND `v`.`published` = '1' AND `s`.`type` = 'frontendurl' AND `s`.`params` LIKE 'com_content%'1.65ms640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `membership_id`,`params` FROM `jos_rsmembership_membership_shared` WHERE `type` = 'menu' AND `published` = '1'371μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `extra_value_id`,`params` FROM `jos_rsmembership_extra_value_shared` WHERE `type` = 'menu' AND `published` = '1'189μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW TABLES2.84ms24.51KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_configuration2.21ms24.56KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin3.05ms1.53KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'acychecker' LIMIT 14.17ms3.95KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'acymailer' LIMIT 1845μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'amazon' LIMIT 11.02ms1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'article' LIMIT 1289μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'birthday' LIMIT 12.7ms1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'brevo' LIMIT 1182μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'createuser' LIMIT 1417μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `groups`.*, `groups`.title AS text, `groups`.id AS `value` FROM jos_usergroups AS `groups`371μs1.08KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'elasticemail' LIMIT 1364μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'forward' LIMIT 11.66ms1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'mailgun' LIMIT 1143μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'module' LIMIT 1118μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'online' LIMIT 1622μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'override' LIMIT 1451μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'phpmail' LIMIT 1367μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'postmark' LIMIT 1210μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'qmail' LIMIT 1718μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'rseventspro' LIMIT 11.03ms1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'segment' LIMIT 1205μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'sendgrid' LIMIT 1209μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'sendinblue' LIMIT 1186μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luecredentials' LIMIT 1545μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'lueintegration' LIMIT 1445μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luetransactional' LIMIT 1869μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luelist' LIMIT 15.46ms1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'lueusers' LIMIT 1157μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luesender' LIMIT 1399μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luecampaign' LIMIT 1885μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luewebhooks' LIMIT 14.28ms1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'sendmail' LIMIT 13.37ms1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'smtp' LIMIT 1188μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'statistics' LIMIT 1164μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'subscriber' LIMIT 1319μs12.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'subscription' LIMIT 1173μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'surveys' LIMIT 1900μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'time' LIMIT 1499μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'user' LIMIT 1255μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'virtuemart' LIMIT 1237μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'managetext' LIMIT 1215μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT s.id, s.template, s.home, s.title AS long_title, s.params FROM jos_template_styles AS s WHERE s.client_id = 0 AND s.template = 'g5_vermilion' ORDER BY s.id327μs912B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `id`,`name`,`rules`,`parent_id` FROM `jos_assets` WHERE `name` IN (:preparedArray1,:preparedArray2,:preparedArray3,:preparedArray4,:preparedArray5,:preparedArray6,:preparedArray7,:preparedArray8,:preparedArray9,:preparedArray10,:preparedArray11,:preparedArray12,:preparedArray13,:preparedArray14,:preparedArray15,:preparedArray16,:preparedArray17,:preparedArray18,:preparedArray19,:preparedArray20,:preparedArray21,:preparedArray22,:preparedArray23,:preparedArray24,:preparedArray25,:preparedArray26,:preparedArray27,:preparedArray28,:preparedArray29,:preparedArray30,:preparedArray31,:preparedArray32,:preparedArray33,:preparedArray34,:preparedArray35,:preparedArray36,:preparedArray37,:preparedArray38,:preparedArray39,:preparedArray40,:preparedArray41,:preparedArray42,:preparedArray43,:preparedArray44,:preparedArray45,:preparedArray46,:preparedArray47,:preparedArray48,:preparedArray49,:preparedArray50,:preparedArray51,:preparedArray52,:preparedArray53,:preparedArray54,:preparedArray55,:preparedArray56)3.62ms8.19KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `id`,`name`,`rules`,`parent_id` FROM `jos_assets` WHERE `name` LIKE :asset OR `name` = :extension OR `parent_id` = 03.15ms213.48KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW FULL COLUMNS FROM `jos_content`949μs1.77KB/plugins/system/falangdriver/falang_database.php:330Copy
  • UPDATE `jos_content` SET `hits` = (`hits` + 1) WHERE `id` = '1689'3.23ms48B/plugins/system/falangdriver/falang_database.php:133Copy
  • SELECT `a`.`id`,`a`.`asset_id`,`a`.`title`,`a`.`alias`,`a`.`introtext`,`a`.`fulltext`,`a`.`state`,`a`.`catid`,`a`.`created`,`a`.`created_by`,`a`.`created_by_alias`,`a`.`modified`,`a`.`modified_by`,`a`.`checked_out`,`a`.`checked_out_time`,`a`.`publish_up`,`a`.`publish_down`,`a`.`images`,`a`.`urls`,`a`.`attribs`,`a`.`version`,`a`.`ordering`,`a`.`metakey`,`a`.`metadesc`,`a`.`access`,`a`.`hits`,`a`.`metadata`,`a`.`featured`,`a`.`language`,`fp`.`featured_up`,`fp`.`featured_down`,`c`.`title` AS `category_title`,`c`.`alias` AS `category_alias`,`c`.`access` AS `category_access`,`c`.`language` AS `category_language`,`fp`.`ordering`,`u`.`name` AS `author`,`parent`.`title` AS `parent_title`,`parent`.`id` AS `parent_id`,`parent`.`path` AS `parent_route`,`parent`.`alias` AS `parent_alias`,`parent`.`language` AS `parent_language`,ROUND(`v`.`rating_sum` / `v`.`rating_count`, 1) AS `rating`,`v`.`rating_count` AS `rating_count` FROM `jos_content` AS `a` INNER JOIN `jos_categories` AS `c` ON `c`.`id` = `a`.`catid` LEFT JOIN `jos_content_frontpage` AS `fp` ON `fp`.`content_id` = `a`.`id` LEFT JOIN `jos_users` AS `u` ON `u`.`id` = `a`.`created_by` LEFT JOIN `jos_categories` AS `parent` ON `parent`.`id` = `c`.`parent_id` LEFT JOIN `jos_content_rating` AS `v` ON `a`.`id` = `v`.`content_id` WHERE ( (`a`.`id` = :pk AND `c`.`published` > 0 AND `a`.`language` IN (:preparedArray1,:preparedArray2)) AND (`a`.`publish_up` IS NULL OR `a`.`publish_up` <= :publishUp)) AND (`a`.`publish_down` IS NULL OR `a`.`publish_down` >= :publishDown) AND `a`.`state` IN (:preparedArray3,:preparedArray4)1.46ms6.19KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1689) AND `reference_table`= 'content'3.24ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (201) AND `reference_table`= 'categories'564μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (201) AND `reference_table`= 'categories'574μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`1.07ms4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'783μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`657μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'2.04ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`868μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'286μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`569μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'408μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `m`.`tag_id`,`t`.* FROM `jos_contentitem_tag_map` AS `m` INNER JOIN `jos_tags` AS `t` ON `m`.`tag_id` = `t`.`id` WHERE `m`.`type_alias` = :contentType AND `m`.`content_item_id` = :id AND `t`.`published` = 1 AND `t`.`access` IN (:preparedArray1,:preparedArray2)1.54ms3.97KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `membership_id`,`params` FROM `jos_rsmembership_membership_shared` WHERE `type` = 'module' AND `published` = '1'180μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `extra_value_id`,`params` FROM `jos_rsmembership_extra_value_shared` WHERE `type` = 'module' AND `published` = '1'276μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'articles') ORDER BY r.ordering, r.id240μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`699μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'367μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT DISTINCT a.id, a.title, a.name, a.checked_out, a.checked_out_time, a.note, a.state, a.access, a.created_time, a.created_user_id, a.ordering, a.language, a.fieldparams, a.params, a.type, a.default_value, a.context, a.group_id, a.label, a.description, a.required, a.only_use_in_subform,l.title AS language_title, l.image AS language_image,uc.name AS editor,ag.title AS access_level,ua.name AS author_name,g.title AS group_title, g.access as group_access, g.state AS group_state, g.note as group_note FROM jos_fields AS a LEFT JOIN `jos_languages` AS l ON l.lang_code = a.language LEFT JOIN jos_users AS uc ON uc.id=a.checked_out LEFT JOIN jos_viewlevels AS ag ON ag.id = a.access LEFT JOIN jos_users AS ua ON ua.id = a.created_user_id LEFT JOIN jos_fields_groups AS g ON g.id = a.group_id LEFT JOIN `jos_fields_categories` AS fc ON fc.field_id = a.id WHERE ( (`a`.`context` = :context AND (`fc`.`category_id` IS NULL OR `fc`.`category_id` IN (:preparedArray1,:preparedArray2,:preparedArray3,:preparedArray4)) AND `a`.`access` IN (:preparedArray5,:preparedArray6)) AND (`a`.`group_id` = 0 OR `g`.`access` IN (:preparedArray7,:preparedArray8)) AND `a`.`state` = :state) AND (`a`.`group_id` = 0 OR `g`.`state` = :gstate) AND `a`.`only_use_in_subform` = :only_use_in_subform ORDER BY a.ordering ASC968μs4.86KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `field_id`,`value` FROM `jos_fields_values` WHERE `field_id` IN (:preparedArray1,:preparedArray2,:preparedArray3) AND `item_id` = :itemid276μs1.45KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT LOWER(REPLACE(a.title, " ", "")) FROM jos_viewlevels as a WHERE a.id IN ('1','7')161μs552B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT LOWER(REPLACE(u.title, " ", "")) FROM jos_usergroups as u WHERE u.id IN ('1')145μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `a`.`id`,`a`.`title`,`a`.`catid`,`a`.`language`, CASE WHEN CHAR_LENGTH(`a`.`alias`) != 0 THEN CONCAT_WS(':', `a`.`id`, `a`.`alias`) ELSE a.id END AS `slug`, CASE WHEN CHAR_LENGTH(`cc`.`alias`) != 0 THEN CONCAT_WS(':', `cc`.`id`, `cc`.`alias`) ELSE cc.id END AS `catslug` FROM `jos_content` AS `a` LEFT JOIN `jos_categories` AS `cc` ON `cc`.`id` = `a`.`catid` WHERE `a`.`catid` = :catid AND `a`.`state` = :state AND `a`.`access` IN (:preparedArray1,:preparedArray2) AND (`publish_up` IS NULL OR `publish_up` <= :nowDate1) AND (`publish_down` IS NULL OR `publish_down` >= :nowDate2) AND `a`.`language` IN (:preparedArray3,:preparedArray4) ORDER BY CASE WHEN `a`.`publish_up` IS NULL THEN `a`.`created` ELSE `a`.`publish_up` END DESC1.14ms2.25KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1685,1682,1683,1684,1687,1688,1689,1690,1691,1692,1693,1694,1695,1696,1697,1698,1699,1700,1701,1702,1703,1704,1705,1706,1707,1708,1709,1710,1711,1712) AND `reference_table`= 'content'705μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`724μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'360μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`648μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'283μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`539μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'297μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`697μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'546μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`1.06ms4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'603μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`828μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'348μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`595μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'321μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`620μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'355μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`532μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'314μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'component') ORDER BY r.ordering, r.id173μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `language`,`id` FROM `jos_menu` WHERE `home` = '1' AND `published` = 1 AND `client_id` = 0592μs592B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (3350) AND `reference_table`= 'menu'266μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`785μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'339μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`570μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'273μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`563μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`536μs4KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,88,90,201) AND `reference_table`= 'categories'325μs8.67KB/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c2`.`language`,CONCAT_WS(':', `c2`.`id`, `c2`.`alias`) AS `id`,CONCAT_WS(':', `ca`.`id`, `ca`.`alias`) AS `catid` FROM `jos_content` AS `c` INNER JOIN `jos_associations` AS `a` ON `a`.`id` = `c`.`id` AND `a`.`context` = :context INNER JOIN `jos_associations` AS `a2` ON `a`.`key` = `a2`.`key` INNER JOIN `jos_content` AS `c2` ON `a2`.`id` = `c2`.`id` INNER JOIN `jos_categories` AS `ca` ON `c2`.`catid` = `ca`.`id` AND `ca`.`extension` = :extension2 WHERE `c`.`id` = :id AND c2.access IN (1,7) AND c2.language != 'en-GB' AND (c2.publish_up IS NULL OR c2.publish_up <= '2025-06-03 16:56:38') AND (c2.publish_down IS NULL OR c2.publish_down >= '2025-06-03 16:56:38') AND c2.state = 1355μs1.47KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `a`.`menutype`,`a`.`title` FROM `jos_menu_types` AS `a` WHERE `a`.`client_id` = 0135μs656B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT m.id, m.alias, m.path AS route, m.level, m.parent_id FROM jos_menu AS m WHERE m.menutype = 'members' AND m.parent_id > 0 AND m.client_id = 0 AND m.published >= 0 ORDER BY m.lft580μs1.98KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (6530,6531,2830,2835,2883,2887,3060,2884,2885,6814,2886,2888,2889,2905,2494,3024,3272,3787,6551,1971,2528,2907,792,793,2906,1173,695,2463,2005,1965,585,4335,3096,2908,2022,2047,2600,2601,2602,7756,487,3025,7755,7428,6644,6642,4642,4645,4577,4644,4643,3026,1972,5585,3800,2084,2096,2087,2088,2089,2090,4444,2093,2094,2092,2091,2095,2097,4607,6411,6552) AND `reference_table`= 'menu'1.26ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT m.id, m.alias, m.path AS route, m.level, m.parent_id FROM jos_menu AS m WHERE m.menutype = 'sub-menu' AND m.parent_id > 0 AND m.client_id = 0 AND m.published >= 0 ORDER BY m.lft266μs784B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (7754,7757) AND `reference_table`= 'menu'251μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT SUM(CASE WHEN `a`.`next_execution` <= :now THEN 1 ELSE 0 END) AS due_count,SUM(CASE WHEN `a`.`locked` IS NULL THEN 0 ELSE 1 END) AS locked_count FROM `jos_scheduler_tasks` AS `a` WHERE `a`.`state` = 1232μs1.37KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_list WHERE type = 'standard'204μs2.08KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_field581μs18.39KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_form WHERE active = 1 AND type != 'shortcode'117μs912B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'head') ORDER BY r.ordering, r.id147μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'body') ORDER BY r.ordering, r.id124μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'everywhere') ORDER BY r.ordering, r.id116μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` LIKE "%regacy" OR `name` LIKE "%\_sub"598μs552B/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW TABLES2.25ms24.51KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `alias`,`id` FROM `jos_content` WHERE id = '463'160μs592B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (463) AND `reference_table`= 'content'223μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`574μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108) AND `reference_table`= 'categories'599μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`418μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108) AND `reference_table`= 'categories'276μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`359μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108) AND `reference_table`= 'categories'271μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`354μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108) AND `reference_table`= 'categories'281μs688B/plugins/system/falangdriver/falang_database.php:325Copy
