CHPSC
Clwb Hwylio Pwllheli Sailing Club
The Heart of Welsh Sailing
Description of the image
{accordion=Log in}
at http://www.pwllhelisailingclub.co.uk/psc/administrator Use user name and password provided. (You must be set up as an Editor - if you are not email secretary@pwllhelisailingclub.co.uk ) {/slider}
{accordion=Find an existing Article}
In the back end - On the top menu go to 'Content' and then 'Article Manager'
To find an existing Article use the filter if the article title (or part of the title is known).
Tip:
Limit the search further by selecting the Category:
  • 'Cruising Event' = these are the articles which are listed on the right hand side of the web site under 'Next Cruise Event' (these are ordered by 'created date')
  • 'Crusing News' = these articles are of a news nature and appear under the menu Cruising News - and could also be a feature article on the front page.
  • 'Cruising Blog' = these articles are intended as 'blog' and will appear under the menu 'Blog'
TIP: Searches can also be made by ordering the articles into date order - eg latest at the top
{/slider}
{accordion=Creat a New Article}
From the tool bar at the top right - click on the icon 'New'
Then on the left hand side of the screen
  • Enter a title for the Article.
  • Alias will be created automatically when you save the document Tip 'Save' regularly.
  • select a Category:
{tab='Crusing News'}
{tab='Cruising Blog'}
  • 'Publish' the article
  • Add the article text - Tip: use Ctrl V to paste from other documents (best to strip out any formatting by copying into notepad and then pasting into the article.
  • On the Right Hand side of the Screen. Article information can be shown or hidden. Usually best left as global.
  • NB - the 'Created Date'  should be changed to the Event Date for articles appearing in the 'Next Cruise Event'I
{/slider}
{accordion= Enhance the Article}
The article can be enhanced by adding photograps and /or images
Links to other articles can be added to the article. These can be to external web pages  or to other articles on the CHPSC site
{/slider}
{accordion= Feature Articles - on the Front Page}
  • For an article to appear on the front page use Feature - 'Yes'
  • Keep the article short - or use the 'read more' feature
  • Add a photograph or image - right aligned and width 150 - to match others.
  • Add links. These can be to external web pages  or to other articles on the CHPSC site
{/slider}
{accordion= Translate}
CHPSC has a bilingual policy and will aim to provide all information on the web site in English and Welsh. The Joomla and Falang extension makes this possible and easy.
We do not, however` want this part of the process  to deter publications or prevent the flow of information. There are many club members and friends who have volunteered to translate content so please send an e-mail tosecretary@pwllhelisailingclub.co.uk so that your article can be translated.
You will note that every part of the site is available in Welsh and English – choose the language of your choice on the top right.
For information about the easy translation method see Translation/Cyfieithu
{/slider}
CalonHwylioCymru
15.019MBMemory Usage652msRequest Duration
Joomla! Version4.4.13
PHP Version8.3.6
Identityguest
Response200
Templateg5_vermilion
Database
Server
mysql
Version
5.7.23-23
Collation
utf8_unicode_ci
Conn Collation
utf8mb4_general_ci
$_GET
array:3 [ "catid" => "111:editing-help" "id" => "739:cruising-articles" "view" => "article" ]
$_POST
$_SESSION
array:1 [ "joomla" => "***redacted***" ]
$_COOKIE
$_SERVER
array:62 [ "LSPHP_ENABLE_USER_INI" => "on" "PATH" => "/usr/local/bin:/usr/bin:/bin" "TEMP" => ...
session
array:3 [ "counter" => 1 "timer" => array:3 [ "start" => 1747070171 "last" => 1747070171...
registry
array:3 [ "data" => [] "initialized" => false "separator" => "." ]
user
array:18 [ "id" => 0 "name" => null "username" => null "email" => null "password" => "***r...
plg_system_languagefilter
array:1 [ "language" => "en-GB" ]
  • afterLoad (458.44KB) (5.38ms)
  • afterInitialise (3.31MB) (76.11ms)
  • afterRoute (2.42MB) (98.37ms)
  • beforeRenderComponent com_content (27.49KB) (255μs)
  • Before Access::preloadComponents (all components) (70.74KB) (1.58ms)
  • After Access::preloadComponents (all components) (143.69KB) (1.51ms)
  • Before Access::preloadPermissions (com_content) (2.1KB) (23μs)
  • After Access::preloadPermissions (com_content) (1.46MB) (6ms)
  • Before Access::getAssetRules (id:637 name:com_content.article.739) (66.65KB) (140μs)
  • After Access::getAssetRules (id:637 name:com_content.article.739) (7.47KB) (139μs)
  • Before Access::getAssetRules (id:1 name:root.1) (827.85KB) (52.73ms)
  • After Access::getAssetRules (id:1 name:root.1) (6.02KB) (39μs)
  • afterRenderComponent com_content (322.24KB) (9.98ms)
  • Before Access::getAssetRules (id:8 name:com_content) (196.32KB) (17.35ms)
  • After Access::getAssetRules (id:8 name:com_content) (6.27KB) (69μs)
  • afterDispatch (10.14KB) (1.2ms)
  • beforeRenderRawModule mod_falang (Quick FaLang Language Switcher) (943.45KB) (15.99ms)
  • afterRenderRawModule mod_falang (Quick FaLang Language Switcher) (1.36MB) (43.69ms)
  • beforeRenderModule mod_falang (Quick FaLang Language Switcher) (736B) (13μs)
  • afterRenderModule mod_falang (Quick FaLang Language Switcher) (3.6KB) (325μs)
  • beforeRenderRawModule mod_breadcrumbs (Navigation) (671.45KB) (16.94ms)
  • afterRenderRawModule mod_breadcrumbs (Navigation) (830.09KB) (75.42ms)
  • beforeRenderModule mod_breadcrumbs (Navigation) (704B) (12μs)
  • afterRenderModule mod_breadcrumbs (Navigation) (3.24KB) (318μs)
  • beforeRenderRawModule mod_menu (Members Site) (20.12KB) (4.64ms)
  • afterRenderRawModule mod_menu (Members Site) (50.22KB) (2.96ms)
  • beforeRenderModule mod_menu (Members Site) (720B) (12μs)
  • afterRenderModule mod_menu (Members Site) (10.55KB) (390μs)
  • beforeRenderRawModule mod_menu (Rules and Policies) (2.45KB) (836μs)
  • afterRenderRawModule mod_menu (Rules and Policies) (55.65KB) (571μs)
  • beforeRenderModule mod_menu (Rules and Policies) (720B) (23μs)
  • afterRenderModule mod_menu (Rules and Policies) (2.62KB) (265μs)
  • beforeRenderRawModule mod_falang (FaLang Language Switcher) (17.7KB) (4.16ms)
  • afterRenderRawModule mod_falang (FaLang Language Switcher) (624.02KB) (18.59ms)
  • beforeRenderModule mod_falang (FaLang Language Switcher) (736B) (11μs)
  • afterRenderModule mod_falang (FaLang Language Switcher) (2.88KB) (273μs)
  • afterRender (506.38KB) (194ms)
  • 1 x afterRender (506.38KB) (29.74%)
    193.98ms
    1 x afterRoute (2.42MB) (15.08%)
    98.37ms
    1 x afterInitialise (3.31MB) (11.67%)
    76.11ms
    1 x afterRenderRawModule mod_breadcrumbs (Navigation) (830.09KB) (11.56%)
    75.42ms
    1 x Before Access::getAssetRules (id:1 name:root.1) (827.85KB) (8.08%)
    52.73ms
    1 x afterRenderRawModule mod_falang (Quick FaLang Language Switcher) (1.36MB) (6.7%)
    43.69ms
    1 x afterRenderRawModule mod_falang (FaLang Language Switcher) (624.02KB) (2.85%)
    18.59ms
    1 x Before Access::getAssetRules (id:8 name:com_content) (196.32KB) (2.66%)
    17.35ms
    1 x beforeRenderRawModule mod_breadcrumbs (Navigation) (671.45KB) (2.6%)
    16.94ms
    1 x beforeRenderRawModule mod_falang (Quick FaLang Language Switcher) (943.45KB) (2.45%)
    15.99ms
    1 x afterRenderComponent com_content (322.24KB) (1.53%)
    9.98ms
    1 x After Access::preloadPermissions (com_content) (1.46MB) (0.92%)
    6.00ms
    1 x afterLoad (458.44KB) (0.83%)
    5.38ms
    1 x beforeRenderRawModule mod_menu (Members Site) (20.12KB) (0.71%)
    4.64ms
    1 x beforeRenderRawModule mod_falang (FaLang Language Switcher) (17.7KB) (0.64%)
    4.16ms
    1 x afterRenderRawModule mod_menu (Members Site) (50.22KB) (0.45%)
    2.96ms
    1 x Before Access::preloadComponents (all components) (70.74KB) (0.24%)
    1.58ms
    1 x After Access::preloadComponents (all components) (143.69KB) (0.23%)
    1.51ms
    1 x afterDispatch (10.14KB) (0.18%)
    1.20ms
    1 x beforeRenderRawModule mod_menu (Rules and Policies) (2.45KB) (0.13%)
    836μs
    1 x afterRenderRawModule mod_menu (Rules and Policies) (55.65KB) (0.09%)
    571μs
    1 x afterRenderModule mod_menu (Members Site) (10.55KB) (0.06%)
    390μs
    1 x afterRenderModule mod_falang (Quick FaLang Language Switcher) (3.6KB) (0.05%)
    325μs
    1 x afterRenderModule mod_breadcrumbs (Navigation) (3.24KB) (0.05%)
    318μs
    1 x afterRenderModule mod_falang (FaLang Language Switcher) (2.88KB) (0.04%)
    273μs
    1 x afterRenderModule mod_menu (Rules and Policies) (2.62KB) (0.04%)
    265μs
    1 x beforeRenderComponent com_content (27.49KB) (0.04%)
    255μs
    1 x Before Access::getAssetRules (id:637 name:com_content.article.739) (66.65KB) (0.02%)
    140μs
    1 x After Access::getAssetRules (id:637 name:com_content.article.739) (7.47KB) (0.02%)
    139μs
    1 x After Access::getAssetRules (id:8 name:com_content) (6.27KB) (0.01%)
    69μs
    1 x After Access::getAssetRules (id:1 name:root.1) (6.02KB) (0.01%)
    39μs
    1 x Before Access::preloadPermissions (com_content) (2.1KB) (0%)
    23μs
    1 x beforeRenderModule mod_menu (Rules and Policies) (720B) (0%)
    23μs
    1 x beforeRenderModule mod_falang (Quick FaLang Language Switcher) (736B) (0%)
    13μs
    1 x beforeRenderModule mod_menu (Members Site) (720B) (0%)
    12μs
    1 x beforeRenderModule mod_breadcrumbs (Navigation) (704B) (0%)
    12μs
    1 x beforeRenderModule mod_falang (FaLang Language Switcher) (736B) (0%)
    11μs
216 statements were executed, 111 of which were duplicates, 105 unique131ms868.06KB
  • select distinct reference_table from jos_falang_content214μs1.01KB/plugins/system/falangdriver/falang_database.php:224Copy
  • SELECT `value` FROM jos_acyc_configuration WHERE `name` = "license_key"127μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acyc_configuration WHERE `name` = "last_cron_trigger"183μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acyc_configuration1.24ms896B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acyc_configuration130μs1.19KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_rsform_config170μs1.81KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_rsmembership_configuration249μs1.56KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'level'154μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'active_cron'113μs1.15KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'cron_next'212μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'queue_type'142μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'cron_frequency'86μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` = 'queue_batch_auto'511μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM `jos_rsmembership_payments` WHERE `published` = '1' ORDER BY `ordering` ASC509μs880B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`membership_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_membership_shared` AS `s` LEFT JOIN `jos_rsmembership_memberships` AS `m` ON `s`.`membership_id` = `m`.`id` WHERE `s`.`published` = '1' AND `m`.`published` = '1' AND `s`.`type` IN ('article','category')2.28ms640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`extra_value_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_extra_value_shared` AS `s` LEFT JOIN `jos_rsmembership_extra_values` AS `v` ON `s`.`extra_value_id` = `v`.`id` WHERE `s`.`published` = '1' AND `v`.`published` = '1' AND `s`.`type` IN ('article','category')546μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `catid` FROM jos_content WHERE `id`='739'578μs1.77KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT joomlatablename,tablepkID FROM `jos_falang_tableinfo`619μs800B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_languages ORDER BY ordering2.04ms1.61KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW FULL COLUMNS FROM `jos_languages`925μs1.52KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `parent_id` FROM jos_categories WHERE `extension`='com_content' AND `id`='111'429μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `parent_id` FROM jos_categories WHERE `extension`='com_content' AND `id`='78'1.98ms536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`membership_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_membership_shared` AS `s` LEFT JOIN `jos_rsmembership_memberships` AS `m` ON `s`.`membership_id` = `m`.`id` WHERE `s`.`published` = '1' AND `m`.`published` = '1' AND `s`.`type` = 'menu' AND `s`.`params` LIKE '2908'953μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`extra_value_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_extra_value_shared` AS `s` LEFT JOIN `jos_rsmembership_extra_values` AS `v` ON `s`.`extra_value_id` = `v`.`id` WHERE `s`.`published` = '1' AND `v`.`published` = '1' AND `s`.`type` = 'menu' AND `s`.`params` LIKE '2908'755μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`membership_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_membership_shared` AS `s` LEFT JOIN `jos_rsmembership_memberships` AS `m` ON `s`.`membership_id` = `m`.`id` WHERE `s`.`published` = '1' AND `m`.`published` = '1' AND `s`.`type` = 'frontendurl' AND `s`.`params` LIKE 'com_content%'4.93ms640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `s`.`extra_value_id`,`s`.`params`,`s`.`type` FROM `jos_rsmembership_extra_value_shared` AS `s` LEFT JOIN `jos_rsmembership_extra_values` AS `v` ON `s`.`extra_value_id` = `v`.`id` WHERE `s`.`published` = '1' AND `v`.`published` = '1' AND `s`.`type` = 'frontendurl' AND `s`.`params` LIKE 'com_content%'210μs640B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `membership_id`,`params` FROM `jos_rsmembership_membership_shared` WHERE `type` = 'menu' AND `published` = '1'199μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `extra_value_id`,`params` FROM `jos_rsmembership_extra_value_shared` WHERE `type` = 'menu' AND `published` = '1'240μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW TABLES3.71ms24.51KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_configuration683μs24.56KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin137μs1.53KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'acychecker' LIMIT 1521μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'acymailer' LIMIT 1138μs3.95KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'amazon' LIMIT 1125μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'article' LIMIT 1121μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'birthday' LIMIT 1122μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'brevo' LIMIT 1131μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'createuser' LIMIT 1106μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `groups`.*, `groups`.title AS text, `groups`.id AS `value` FROM jos_usergroups AS `groups`106μs1.08KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'elasticemail' LIMIT 1132μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'forward' LIMIT 12.32ms1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'mailgun' LIMIT 1207μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'module' LIMIT 1553μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'online' LIMIT 1204μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'override' LIMIT 1195μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'phpmail' LIMIT 13.14ms1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'postmark' LIMIT 1161μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'qmail' LIMIT 1132μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'rseventspro' LIMIT 1196μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'segment' LIMIT 1115μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'sendgrid' LIMIT 1199μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'sendinblue' LIMIT 1165μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luecredentials' LIMIT 1108μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'lueintegration' LIMIT 1170μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luetransactional' LIMIT 1106μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luelist' LIMIT 1180μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'lueusers' LIMIT 1103μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luesender' LIMIT 1111μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luecampaign' LIMIT 1114μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'luewebhooks' LIMIT 1115μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'sendmail' LIMIT 1127μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'smtp' LIMIT 1119μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'statistics' LIMIT 1112μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'subscriber' LIMIT 1125μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'subscription' LIMIT 1114μs12.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'surveys' LIMIT 1125μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'time' LIMIT 1113μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'user' LIMIT 1133μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'virtuemart' LIMIT 1121μs1.47KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_plugin WHERE folder_name = 'managetext' LIMIT 1121μs1.45KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT s.id, s.template, s.home, s.title AS long_title, s.params FROM jos_template_styles AS s WHERE s.client_id = 0 AND s.template = 'g5_vermilion' ORDER BY s.id194μs912B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `id`,`name`,`rules`,`parent_id` FROM `jos_assets` WHERE `name` IN (:preparedArray1,:preparedArray2,:preparedArray3,:preparedArray4,:preparedArray5,:preparedArray6,:preparedArray7,:preparedArray8,:preparedArray9,:preparedArray10,:preparedArray11,:preparedArray12,:preparedArray13,:preparedArray14,:preparedArray15,:preparedArray16,:preparedArray17,:preparedArray18,:preparedArray19,:preparedArray20,:preparedArray21,:preparedArray22,:preparedArray23,:preparedArray24,:preparedArray25,:preparedArray26,:preparedArray27,:preparedArray28,:preparedArray29,:preparedArray30,:preparedArray31,:preparedArray32,:preparedArray33,:preparedArray34,:preparedArray35,:preparedArray36,:preparedArray37,:preparedArray38,:preparedArray39,:preparedArray40,:preparedArray41,:preparedArray42,:preparedArray43,:preparedArray44,:preparedArray45,:preparedArray46,:preparedArray47,:preparedArray48,:preparedArray49,:preparedArray50,:preparedArray51,:preparedArray52,:preparedArray53,:preparedArray54,:preparedArray55,:preparedArray56)959μs8.19KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `id`,`name`,`rules`,`parent_id` FROM `jos_assets` WHERE `name` LIKE :asset OR `name` = :extension OR `parent_id` = 03.27ms213.48KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW FULL COLUMNS FROM `jos_content`458μs1.77KB/plugins/system/falangdriver/falang_database.php:330Copy
  • UPDATE `jos_content` SET `hits` = (`hits` + 1) WHERE `id` = '739'208μs48B/plugins/system/falangdriver/falang_database.php:133Copy
  • SELECT `a`.`id`,`a`.`asset_id`,`a`.`title`,`a`.`alias`,`a`.`introtext`,`a`.`fulltext`,`a`.`state`,`a`.`catid`,`a`.`created`,`a`.`created_by`,`a`.`created_by_alias`,`a`.`modified`,`a`.`modified_by`,`a`.`checked_out`,`a`.`checked_out_time`,`a`.`publish_up`,`a`.`publish_down`,`a`.`images`,`a`.`urls`,`a`.`attribs`,`a`.`version`,`a`.`ordering`,`a`.`metakey`,`a`.`metadesc`,`a`.`access`,`a`.`hits`,`a`.`metadata`,`a`.`featured`,`a`.`language`,`fp`.`featured_up`,`fp`.`featured_down`,`c`.`title` AS `category_title`,`c`.`alias` AS `category_alias`,`c`.`access` AS `category_access`,`c`.`language` AS `category_language`,`fp`.`ordering`,`u`.`name` AS `author`,`parent`.`title` AS `parent_title`,`parent`.`id` AS `parent_id`,`parent`.`path` AS `parent_route`,`parent`.`alias` AS `parent_alias`,`parent`.`language` AS `parent_language`,ROUND(`v`.`rating_sum` / `v`.`rating_count`, 1) AS `rating`,`v`.`rating_count` AS `rating_count` FROM `jos_content` AS `a` INNER JOIN `jos_categories` AS `c` ON `c`.`id` = `a`.`catid` LEFT JOIN `jos_content_frontpage` AS `fp` ON `fp`.`content_id` = `a`.`id` LEFT JOIN `jos_users` AS `u` ON `u`.`id` = `a`.`created_by` LEFT JOIN `jos_categories` AS `parent` ON `parent`.`id` = `c`.`parent_id` LEFT JOIN `jos_content_rating` AS `v` ON `a`.`id` = `v`.`content_id` WHERE ( (`a`.`id` = :pk AND `c`.`published` > 0 AND `a`.`language` IN (:preparedArray1,:preparedArray2)) AND (`a`.`publish_up` IS NULL OR `a`.`publish_up` <= :publishUp)) AND (`a`.`publish_down` IS NULL OR `a`.`publish_down` >= :publishDown) AND `a`.`state` IN (:preparedArray3,:preparedArray4)538μs22.19KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (739) AND `reference_table`= 'content'528μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (111) AND `reference_table`= 'categories'205μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (111) AND `reference_table`= 'categories'165μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`389μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'316μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`682μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'301μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`362μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'263μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`379μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'416μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `m`.`tag_id`,`t`.* FROM `jos_contentitem_tag_map` AS `m` INNER JOIN `jos_tags` AS `t` ON `m`.`tag_id` = `t`.`id` WHERE `m`.`type_alias` = :contentType AND `m`.`content_item_id` = :id AND `t`.`published` = 1 AND `t`.`access` IN (:preparedArray1,:preparedArray2)236μs3.97KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `m`.`id`,`m`.`title`,`m`.`module`,`m`.`position`,`m`.`content`,`m`.`showtitle`,`m`.`params`,`mm`.`menuid` FROM `jos_modules` AS `m` LEFT JOIN `jos_modules_menu` AS `mm` ON `mm`.`moduleid` = `m`.`id` LEFT JOIN `jos_extensions` AS `e` ON `e`.`element` = `m`.`module` AND `e`.`client_id` = `m`.`client_id` WHERE ( ( (`m`.`published` = 1 AND `e`.`enabled` = 1 AND `m`.`client_id` = :clientId AND `m`.`access` IN (:preparedArray1,:preparedArray2)) AND (`m`.`publish_up` IS NULL OR `m`.`publish_up` <= :publishUp)) AND (`m`.`publish_down` IS NULL OR `m`.`publish_down` >= :publishDown)) AND (`mm`.`menuid` = :itemId OR `mm`.`menuid` <= 0) AND `m`.`language` IN (:preparedArray3,:preparedArray4) ORDER BY `m`.`position`,`m`.`ordering`2.51ms50.84KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (317,328,332,333,337,353,356,108,373,374,414,419,421,422,424,435,436,438,439,449,450,451,452,453,454,457,458,459,460,461,463,465,466,467,468,472,474,475,476,477,478,501,502,503,504,506,294,94,338,87,97,282,349,386,388,296) AND `reference_table`= 'modules'1.23ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `membership_id`,`params` FROM `jos_rsmembership_membership_shared` WHERE `type` = 'module' AND `published` = '1'77μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `extra_value_id`,`params` FROM `jos_rsmembership_extra_value_shared` WHERE `type` = 'module' AND `published` = '1'69μs576B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'articles') ORDER BY r.ordering, r.id152μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`410μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'261μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT DISTINCT a.id, a.title, a.name, a.checked_out, a.checked_out_time, a.note, a.state, a.access, a.created_time, a.created_user_id, a.ordering, a.language, a.fieldparams, a.params, a.type, a.default_value, a.context, a.group_id, a.label, a.description, a.required, a.only_use_in_subform,l.title AS language_title, l.image AS language_image,uc.name AS editor,ag.title AS access_level,ua.name AS author_name,g.title AS group_title, g.access as group_access, g.state AS group_state, g.note as group_note FROM jos_fields AS a LEFT JOIN `jos_languages` AS l ON l.lang_code = a.language LEFT JOIN jos_users AS uc ON uc.id=a.checked_out LEFT JOIN jos_viewlevels AS ag ON ag.id = a.access LEFT JOIN jos_users AS ua ON ua.id = a.created_user_id LEFT JOIN jos_fields_groups AS g ON g.id = a.group_id LEFT JOIN `jos_fields_categories` AS fc ON fc.field_id = a.id WHERE ( (`a`.`context` = :context AND (`fc`.`category_id` IS NULL OR `fc`.`category_id` IN (:preparedArray1,:preparedArray2,:preparedArray3)) AND `a`.`access` IN (:preparedArray4,:preparedArray5)) AND (`a`.`group_id` = 0 OR `g`.`access` IN (:preparedArray6,:preparedArray7)) AND `a`.`state` = :state) AND (`a`.`group_id` = 0 OR `g`.`state` = :gstate) AND `a`.`only_use_in_subform` = :only_use_in_subform ORDER BY a.ordering ASC804μs4.81KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT LOWER(REPLACE(a.title, " ", "")) FROM jos_viewlevels as a WHERE a.id IN ('1','7')155μs552B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT LOWER(REPLACE(u.title, " ", "")) FROM jos_usergroups as u WHERE u.id IN ('1')103μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `a`.`id`,`a`.`title`,`a`.`catid`,`a`.`language`, CASE WHEN CHAR_LENGTH(`a`.`alias`) != 0 THEN CONCAT_WS(':', `a`.`id`, `a`.`alias`) ELSE a.id END AS `slug`, CASE WHEN CHAR_LENGTH(`cc`.`alias`) != 0 THEN CONCAT_WS(':', `cc`.`id`, `cc`.`alias`) ELSE cc.id END AS `catslug` FROM `jos_content` AS `a` LEFT JOIN `jos_categories` AS `cc` ON `cc`.`id` = `a`.`catid` WHERE `a`.`catid` = :catid AND `a`.`state` = :state AND `a`.`access` IN (:preparedArray1,:preparedArray2) AND (`publish_up` IS NULL OR `publish_up` <= :nowDate1) AND (`publish_down` IS NULL OR `publish_down` >= :nowDate2) AND `a`.`language` IN (:preparedArray3,:preparedArray4) ORDER BY CASE WHEN `a`.`publish_up` IS NULL THEN `a`.`created` ELSE `a`.`publish_up` END DESC519μs1.77KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (739) AND `reference_table`= 'content'188μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`386μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'306μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'component') ORDER BY r.ordering, r.id187μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `language`,`id` FROM `jos_menu` WHERE `home` = '1' AND `published` = 1 AND `client_id` = 0602μs592B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (3350) AND `reference_table`= 'menu'194μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`409μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'315μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`401μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'752μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`383μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'499μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`408μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'282μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c2`.`language`,CONCAT_WS(':', `c2`.`id`, `c2`.`alias`) AS `id`,CONCAT_WS(':', `ca`.`id`, `ca`.`alias`) AS `catid` FROM `jos_content` AS `c` INNER JOIN `jos_associations` AS `a` ON `a`.`id` = `c`.`id` AND `a`.`context` = :context INNER JOIN `jos_associations` AS `a2` ON `a`.`key` = `a2`.`key` INNER JOIN `jos_content` AS `c2` ON `a2`.`id` = `c2`.`id` INNER JOIN `jos_categories` AS `ca` ON `c2`.`catid` = `ca`.`id` AND `ca`.`extension` = :extension2 WHERE `c`.`id` = :id AND c2.access IN (1,7) AND c2.language != 'en-GB' AND (c2.publish_up IS NULL OR c2.publish_up <= '2025-05-12 17:16:11') AND (c2.publish_down IS NULL OR c2.publish_down >= '2025-05-12 17:16:11') AND c2.state = 1311μs1.47KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `c2`.`language`,`c2`.`id` FROM `jos_menu` AS `c` INNER JOIN `jos_associations` AS `a` ON `a`.`id` = `c`.`id` AND `a`.`context` = :context INNER JOIN `jos_associations` AS `a2` ON `a`.`key` = `a2`.`key` INNER JOIN `jos_menu` AS `c2` ON `a2`.`id` = `c2`.`id` WHERE `c`.`id` = :id212μs1.38KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT fc.value FROM jos_falang_content fc WHERE fc.reference_id = 2908 AND fc.language_id = 2 AND fc.reference_field = 'params' AND fc.published = 1 AND fc.reference_table = 'menu'222μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `a`.`id`,`a`.`asset_id`,`a`.`title`,`a`.`alias`,`a`.`introtext`,`a`.`fulltext`,`a`.`state`,`a`.`catid`,`a`.`created`,`a`.`created_by`,`a`.`created_by_alias`,`a`.`modified`,`a`.`modified_by`,`a`.`checked_out`,`a`.`checked_out_time`,`a`.`publish_up`,`a`.`publish_down`,`a`.`images`,`a`.`urls`,`a`.`attribs`,`a`.`version`,`a`.`ordering`,`a`.`metakey`,`a`.`metadesc`,`a`.`access`,`a`.`hits`,`a`.`metadata`,`a`.`featured`,`a`.`language`,`fp`.`featured_up`,`fp`.`featured_down`,`c`.`title` AS `category_title`,`c`.`alias` AS `category_alias`,`c`.`access` AS `category_access`,`c`.`language` AS `category_language`,`fp`.`ordering`,`u`.`name` AS `author`,`parent`.`title` AS `parent_title`,`parent`.`id` AS `parent_id`,`parent`.`path` AS `parent_route`,`parent`.`alias` AS `parent_alias`,`parent`.`language` AS `parent_language`,ROUND(`v`.`rating_sum` / `v`.`rating_count`, 1) AS `rating`,`v`.`rating_count` AS `rating_count` FROM `jos_content` AS `a` INNER JOIN `jos_categories` AS `c` ON `c`.`id` = `a`.`catid` LEFT JOIN `jos_content_frontpage` AS `fp` ON `fp`.`content_id` = `a`.`id` LEFT JOIN `jos_users` AS `u` ON `u`.`id` = `a`.`created_by` LEFT JOIN `jos_categories` AS `parent` ON `parent`.`id` = `c`.`parent_id` LEFT JOIN `jos_content_rating` AS `v` ON `a`.`id` = `v`.`content_id` WHERE ( (`a`.`id` = :pk AND `c`.`published` > 0) AND (`a`.`publish_up` IS NULL OR `a`.`publish_up` <= :publishUp)) AND (`a`.`publish_down` IS NULL OR `a`.`publish_down` >= :publishDown)423μs22.13KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (739) AND `reference_table`= 'content'230μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=2 AND `published`= 1 AND `reference_id`IN (111) AND `reference_table`= 'categories'173μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=2 AND `published`= 1 AND `reference_id`IN (111) AND `reference_table`= 'categories'166μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT fc.value FROM jos_falang_content fc WHERE fc.reference_id = 739 AND fc.language_id = 2 AND fc.reference_field = 'alias' AND fc.published = 1 AND fc.reference_table = 'content'187μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `alias` FROM `jos_content` WHERE id = '739'109μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`459μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=2 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'244μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`407μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=2 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'226μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT fc.value FROM jos_falang_content fc WHERE fc.reference_id = 739 AND fc.language_id = 2 AND fc.reference_field = 'alias' AND fc.published = 1 AND fc.reference_table = 'content'207μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT fc.value FROM jos_falang_content fc WHERE fc.reference_id = 111 AND fc.language_id = 2 AND fc.reference_field = 'alias' AND fc.published = 1 AND fc.reference_table = 'categories'165μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`397μs11.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=2 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'246μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=2 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'234μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT fc.value FROM jos_falang_content fc WHERE fc.reference_id = 2908 AND fc.language_id = 2 AND fc.reference_field = 'path' AND fc.published = 1 AND fc.reference_table = 'menu'279μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW FULL COLUMNS FROM `jos_menu`440μs1.7KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM `jos_menu` WHERE `id` = '2908'187μs2.84KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (2908) AND `reference_table`= 'menu'185μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT p.*, jfc.value as jfcvalue FROM jos_menu AS n, jos_menu AS p LEFT JOIN jos_falang_content as jfc ON jfc.reference_table='menu' AND jfc.reference_id=p.id AND jfc.language_id='2' and jfc.reference_field='alias' WHERE n.lft BETWEEN p.lft AND p.rgt AND n.id = 2908 AND p.client_id = 0 ORDER BY p.lft380μs3.02KB/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT m.path FROM jos_menu m WHERE m.id = 290897μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT fc.value FROM jos_falang_content fc WHERE fc.reference_id = 2908 AND fc.language_id = 1 AND fc.reference_field = 'path' AND fc.published = 1 AND fc.reference_table = 'menu'199μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM `jos_menu` WHERE `id` = '2908'167μs2.84KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (2908) AND `reference_table`= 'menu'174μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT p.*, jfc.value as jfcvalue FROM jos_menu AS n, jos_menu AS p LEFT JOIN jos_falang_content as jfc ON jfc.reference_table='menu' AND jfc.reference_id=p.id AND jfc.language_id='1' and jfc.reference_field='alias' WHERE n.lft BETWEEN p.lft AND p.rgt AND n.id = 2908 AND p.client_id = 0 ORDER BY p.lft537μs3.02KB/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `a`.`id`,`a`.`asset_id`,`a`.`title`,`a`.`alias`,`a`.`introtext`,`a`.`fulltext`,`a`.`state`,`a`.`catid`,`a`.`created`,`a`.`created_by`,`a`.`created_by_alias`,`a`.`modified`,`a`.`modified_by`,`a`.`checked_out`,`a`.`checked_out_time`,`a`.`publish_up`,`a`.`publish_down`,`a`.`images`,`a`.`urls`,`a`.`attribs`,`a`.`version`,`a`.`ordering`,`a`.`metakey`,`a`.`metadesc`,`a`.`access`,`a`.`hits`,`a`.`metadata`,`a`.`featured`,`a`.`language`,`fp`.`featured_up`,`fp`.`featured_down`,`c`.`title` AS `category_title`,`c`.`alias` AS `category_alias`,`c`.`access` AS `category_access`,`c`.`language` AS `category_language`,`fp`.`ordering`,`u`.`name` AS `author`,`parent`.`title` AS `parent_title`,`parent`.`id` AS `parent_id`,`parent`.`path` AS `parent_route`,`parent`.`alias` AS `parent_alias`,`parent`.`language` AS `parent_language`,ROUND(`v`.`rating_sum` / `v`.`rating_count`, 1) AS `rating`,`v`.`rating_count` AS `rating_count` FROM `jos_content` AS `a` INNER JOIN `jos_categories` AS `c` ON `c`.`id` = `a`.`catid` LEFT JOIN `jos_content_frontpage` AS `fp` ON `fp`.`content_id` = `a`.`id` LEFT JOIN `jos_users` AS `u` ON `u`.`id` = `a`.`created_by` LEFT JOIN `jos_categories` AS `parent` ON `parent`.`id` = `c`.`parent_id` LEFT JOIN `jos_content_rating` AS `v` ON `a`.`id` = `v`.`content_id` WHERE ( (`a`.`id` = :pk AND `c`.`published` > 0) AND (`a`.`publish_up` IS NULL OR `a`.`publish_up` <= :publishUp)) AND (`a`.`publish_down` IS NULL OR `a`.`publish_down` >= :publishDown)405μs22.13KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (739) AND `reference_table`= 'content'257μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (111) AND `reference_table`= 'categories'352μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (111) AND `reference_table`= 'categories'172μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT alias FROM jos_content WHERE id = 739106μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`611μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'324μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`496μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'661μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`406μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'288μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'308μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `a`.`menutype`,`a`.`title` FROM `jos_menu_types` AS `a` WHERE `a`.`client_id` = 0150μs656B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT m.id, m.alias, m.path AS route, m.level, m.parent_id FROM jos_menu AS m WHERE m.menutype = 'members' AND m.parent_id > 0 AND m.client_id = 0 AND m.published >= 0 ORDER BY m.lft607μs1.98KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (6530,6531,2830,2835,2883,2887,3060,2884,2885,6814,2886,2888,2889,2905,2494,3024,3272,3787,6551,1971,2528,2907,792,793,2906,1173,695,2463,2005,1965,585,4335,3096,2908,2022,2047,2600,2601,2602,7756,487,3025,7755,7428,6644,6642,4642,4645,4577,4644,4643,3026,1972,5585,3800,2084,2096,2087,2088,2089,2090,4444,2093,2094,2092,2091,2095,2097,4607,6411,6552) AND `reference_table`= 'menu'1.7ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT m.id, m.alias, m.path AS route, m.level, m.parent_id FROM jos_menu AS m WHERE m.menutype = 'sub-menu' AND m.parent_id > 0 AND m.client_id = 0 AND m.published >= 0 ORDER BY m.lft303μs784B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (7754,7757) AND `reference_table`= 'menu'225μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`657μs20.19KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108,111,113,115,117,118,119,124,127,130,144,156,205,246) AND `reference_table`= 'categories'569μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`736μs20.19KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108,111,113,115,117,118,119,124,127,130,144,156,205,246) AND `reference_table`= 'categories'707μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`612μs20.19KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108,111,113,115,117,118,119,124,127,130,144,156,205,246) AND `reference_table`= 'categories'997μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`1.31ms20.19KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108,111,113,115,117,118,119,124,127,130,144,156,205,246) AND `reference_table`= 'categories'5.39ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`5.95ms3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'970μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`629μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'1.57ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`638μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'1.35ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`436μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,111) AND `reference_table`= 'categories'295μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT fc.value FROM jos_falang_content fc WHERE fc.reference_id = 2908 AND fc.language_id = 2 AND fc.reference_field = 'params' AND fc.published = 1 AND fc.reference_table = 'menu'246μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `a`.`id`,`a`.`asset_id`,`a`.`title`,`a`.`alias`,`a`.`introtext`,`a`.`fulltext`,`a`.`state`,`a`.`catid`,`a`.`created`,`a`.`created_by`,`a`.`created_by_alias`,`a`.`modified`,`a`.`modified_by`,`a`.`checked_out`,`a`.`checked_out_time`,`a`.`publish_up`,`a`.`publish_down`,`a`.`images`,`a`.`urls`,`a`.`attribs`,`a`.`version`,`a`.`ordering`,`a`.`metakey`,`a`.`metadesc`,`a`.`access`,`a`.`hits`,`a`.`metadata`,`a`.`featured`,`a`.`language`,`fp`.`featured_up`,`fp`.`featured_down`,`c`.`title` AS `category_title`,`c`.`alias` AS `category_alias`,`c`.`access` AS `category_access`,`c`.`language` AS `category_language`,`fp`.`ordering`,`u`.`name` AS `author`,`parent`.`title` AS `parent_title`,`parent`.`id` AS `parent_id`,`parent`.`path` AS `parent_route`,`parent`.`alias` AS `parent_alias`,`parent`.`language` AS `parent_language`,ROUND(`v`.`rating_sum` / `v`.`rating_count`, 1) AS `rating`,`v`.`rating_count` AS `rating_count` FROM `jos_content` AS `a` INNER JOIN `jos_categories` AS `c` ON `c`.`id` = `a`.`catid` LEFT JOIN `jos_content_frontpage` AS `fp` ON `fp`.`content_id` = `a`.`id` LEFT JOIN `jos_users` AS `u` ON `u`.`id` = `a`.`created_by` LEFT JOIN `jos_categories` AS `parent` ON `parent`.`id` = `c`.`parent_id` LEFT JOIN `jos_content_rating` AS `v` ON `a`.`id` = `v`.`content_id` WHERE ( (`a`.`id` = :pk AND `c`.`published` > 0) AND (`a`.`publish_up` IS NULL OR `a`.`publish_up` <= :publishUp)) AND (`a`.`publish_down` IS NULL OR `a`.`publish_down` >= :publishDown)459μs22.13KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (739) AND `reference_table`= 'content'223μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=2 AND `published`= 1 AND `reference_id`IN (111) AND `reference_table`= 'categories'199μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT fc.value FROM jos_falang_content fc WHERE fc.reference_id = 739 AND fc.language_id = 2 AND fc.reference_field = 'alias' AND fc.published = 1 AND fc.reference_table = 'content'219μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `alias` FROM `jos_content` WHERE id = '739'129μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT fc.value FROM jos_falang_content fc WHERE fc.reference_id = 2908 AND fc.language_id = 2 AND fc.reference_field = 'path' AND fc.published = 1 AND fc.reference_table = 'menu'198μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM `jos_menu` WHERE `id` = '2908'199μs2.84KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (2908) AND `reference_table`= 'menu'189μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT p.*, jfc.value as jfcvalue FROM jos_menu AS n, jos_menu AS p LEFT JOIN jos_falang_content as jfc ON jfc.reference_table='menu' AND jfc.reference_id=p.id AND jfc.language_id='2' and jfc.reference_field='alias' WHERE n.lft BETWEEN p.lft AND p.rgt AND n.id = 2908 AND p.client_id = 0 ORDER BY p.lft401μs3.02KB/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT m.path FROM jos_menu m WHERE m.id = 2908100μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT fc.value FROM jos_falang_content fc WHERE fc.reference_id = 2908 AND fc.language_id = 1 AND fc.reference_field = 'path' AND fc.published = 1 AND fc.reference_table = 'menu'180μs520B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT p.*, jfc.value as jfcvalue FROM jos_menu AS n, jos_menu AS p LEFT JOIN jos_falang_content as jfc ON jfc.reference_table='menu' AND jfc.reference_id=p.id AND jfc.language_id='1' and jfc.reference_field='alias' WHERE n.lft BETWEEN p.lft AND p.rgt AND n.id = 2908 AND p.client_id = 0 ORDER BY p.lft386μs3.02KB/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `a`.`id`,`a`.`asset_id`,`a`.`title`,`a`.`alias`,`a`.`introtext`,`a`.`fulltext`,`a`.`state`,`a`.`catid`,`a`.`created`,`a`.`created_by`,`a`.`created_by_alias`,`a`.`modified`,`a`.`modified_by`,`a`.`checked_out`,`a`.`checked_out_time`,`a`.`publish_up`,`a`.`publish_down`,`a`.`images`,`a`.`urls`,`a`.`attribs`,`a`.`version`,`a`.`ordering`,`a`.`metakey`,`a`.`metadesc`,`a`.`access`,`a`.`hits`,`a`.`metadata`,`a`.`featured`,`a`.`language`,`fp`.`featured_up`,`fp`.`featured_down`,`c`.`title` AS `category_title`,`c`.`alias` AS `category_alias`,`c`.`access` AS `category_access`,`c`.`language` AS `category_language`,`fp`.`ordering`,`u`.`name` AS `author`,`parent`.`title` AS `parent_title`,`parent`.`id` AS `parent_id`,`parent`.`path` AS `parent_route`,`parent`.`alias` AS `parent_alias`,`parent`.`language` AS `parent_language`,ROUND(`v`.`rating_sum` / `v`.`rating_count`, 1) AS `rating`,`v`.`rating_count` AS `rating_count` FROM `jos_content` AS `a` INNER JOIN `jos_categories` AS `c` ON `c`.`id` = `a`.`catid` LEFT JOIN `jos_content_frontpage` AS `fp` ON `fp`.`content_id` = `a`.`id` LEFT JOIN `jos_users` AS `u` ON `u`.`id` = `a`.`created_by` LEFT JOIN `jos_categories` AS `parent` ON `parent`.`id` = `c`.`parent_id` LEFT JOIN `jos_content_rating` AS `v` ON `a`.`id` = `v`.`content_id` WHERE ( (`a`.`id` = :pk AND `c`.`published` > 0) AND (`a`.`publish_up` IS NULL OR `a`.`publish_up` <= :publishUp)) AND (`a`.`publish_down` IS NULL OR `a`.`publish_down` >= :publishDown)437μs22.13KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (739) AND `reference_table`= 'content'236μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (111) AND `reference_table`= 'categories'198μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (111) AND `reference_table`= 'categories'191μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT alias FROM jos_content WHERE id = 739120μs536B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT SUM(CASE WHEN `a`.`next_execution` <= :now THEN 1 ELSE 0 END) AS due_count,SUM(CASE WHEN `a`.`locked` IS NULL THEN 0 ELSE 1 END) AS locked_count FROM `jos_scheduler_tasks` AS `a` WHERE `a`.`state` = 1161μs1.37KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_list WHERE type = 'standard'252μs2.08KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_field284μs18.39KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT * FROM jos_acym_form WHERE active = 1 AND type != 'shortcode'131μs912B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'head') ORDER BY r.ordering, r.id160μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'body') ORDER BY r.ordering, r.id144μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT r.* FROM jos_rereplacer AS r WHERE r.published = 1 AND (r.area = 'everywhere') ORDER BY r.ordering, r.id119μs1.48KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `value` FROM jos_acym_configuration WHERE `name` LIKE "%regacy" OR `name` LIKE "%\_sub"613μs552B/plugins/system/falangdriver/falang_database.php:330Copy
  • SHOW TABLES2.72ms24.51KB/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT `alias`,`id` FROM `jos_content` WHERE id = '463'2.91ms592B/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (463) AND `reference_table`= 'content'2.34ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`4.35ms3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108) AND `reference_table`= 'categories'1.98ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`2.4ms3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108) AND `reference_table`= 'categories'829μs688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`4.23ms3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108) AND `reference_table`= 'categories'4.38ms688B/plugins/system/falangdriver/falang_database.php:325Copy
  • SELECT `c`.`id`,`c`.`asset_id`,`c`.`access`,`c`.`alias`,`c`.`checked_out`,`c`.`checked_out_time`,`c`.`created_time`,`c`.`created_user_id`,`c`.`description`,`c`.`extension`,`c`.`hits`,`c`.`language`,`c`.`level`,`c`.`lft`,`c`.`metadata`,`c`.`metadesc`,`c`.`metakey`,`c`.`modified_time`,`c`.`note`,`c`.`params`,`c`.`parent_id`,`c`.`path`,`c`.`published`,`c`.`rgt`,`c`.`title`,`c`.`modified_user_id`,`c`.`version`, CASE WHEN CHAR_LENGTH(`c`.`alias`) != 0 THEN CONCAT_WS(':', `c`.`id`, `c`.`alias`) ELSE `c`.`id` END as `slug` FROM `jos_categories` AS `s` INNER JOIN `jos_categories` AS `c` ON (`s`.`lft` < `c`.`lft` AND `c`.`lft` < `s`.`rgt` AND `c`.`language` IN (:preparedArray3,:preparedArray4)) OR (`c`.`lft` <= `s`.`lft` AND `s`.`rgt` <= `c`.`rgt`) WHERE (`c`.`extension` = :extension OR `c`.`extension` = 'system') AND `c`.`access` IN (:preparedArray1,:preparedArray2) AND `c`.`published` = 1 AND `s`.`id` = :id ORDER BY `c`.`lft`719μs3.98KBParams/plugins/system/falangdriver/falang_database.php:330Copy
  • SELECT reference_field, value, reference_id, original_value FROM `jos_falang_content` WHERE `language_id`=1 AND `published`= 1 AND `reference_id`IN (1,78,108) AND `reference_table`= 'categories'1.02ms688B/plugins/system/falangdriver/falang_database.php:325Copy
